Troubleshooting Swapped engine
Old Aug 31, 2008 | 06:57 PM
cabrio_for_my_kid's Avatar
Default Troubleshooting Swapped engine
I purchased a 89 cabriolet which had been extensively customized. When I limped it home the obvious problems were that the muffler had been removed and it hesitates badly on acceleration. Prior to fixing those, I decided to clean up some poorly done repairs (three bolts instead of five that sort of thing) and particularly the electrical system. A jetta 91 (9A) 16valve engine was swapped in. It runs well and has great compression (no surprise since it newly rebuilt by a pro), but the wiring was a rat's nest. I meticulously rebuilt the harnesses using the relevant sections of the jetta and cabriolet diagrams. I have checked and doublechecked the wiring and still can't get a spark.
The part I am not sure I have right is at the ignition switch coil and fuel pumps. This is where the two harnesses intersect. Anybody know of a resource I can use as a guide? Maybe an engine swapping howto or diagram?
lindalee
Oct 8, 2013 12:17 AM
JJeffers
Oct 8, 2010 07:23 AM
Sep 18, 2010 05:34 AM
frustrated_jetta_owner
Nov 11, 2009 05:43 AM
drioux
Apr 1, 2008 12:47 PM
