Trouble codes
Old Jun 11, 2005 | 06:09 AM
chivoon's Avatar
Default Trouble codes
I have a 1998 Passat 1.8 4 cyl and I am getting trouble codes p1136 (fuel trim too rich at idle) and P1613 (Transmission control module, short to B+)
does anyone have an idea on what might be causing this?
can the 2 be related?
Thank you
Chivoon
Old Jun 11, 2005 | 02:56 PM
patrick's Avatar
Administrator
Default RE: trouble codes
i think that they could be related...if the transmission is having troubles, the ecu may be trying to compensate with added fuel...
Old Mar 5, 2012 | 12:04 PM
seanr37715's Avatar
i have my glow plug lite flashing on my t4 transporter dont know what to do ?
Old Mar 5, 2012 | 06:36 PM
Welcome to the forum guys. Name:  VWwelcome.gif
VAG Error Code: 17544
EOBD II Error Code: P1136
Fault Location:
Long term fuel trim, idling, bank 1 - system too lean
Possible Cause:
Fuel pressure/pump.
Injector(s).
Intake/exhaust leak.
Secondary air injection (AIR) system.
Hose leak.
VAG Error Code: 18021
EOBD II Error Code: P1613
Fault Location:
Malfunction indicator lamp (MIL) - open circuit/short to positive
Possible Cause:
Malfunction indicator lamp (MIL) Triggered on first occurrence.
Wiring open circuit/short to positive.
Wiring/Connectors from/to Malfunction Indicator Lamp (MIL) faulty
Control Module Cording incorrect.
Possible Solutions:
Check Malfunction Indicator Lamp (MIL).
Check Wiring/Connectors from/to Malfunction Indicator Lamp (MIL).
Check Control Module Coding.
Last edited by Keithuk; Apr 18, 2012 at 07:48 PM. Reason: Tidy up layout but it won't
Old Mar 19, 2012 | 01:31 AM
coqwwpor's Avatar
p1136 problem: You're getting too much air or not enough fuel (clogged injectors, fuel pump or filter issues).
Old Mar 20, 2012 | 02:20 PM
seanr37715's Avatar
hi i had a short on the rear lights
Old Mar 29, 2012 | 11:49 PM
  #7
Strouthern's Avatar
You've most likely got a blown out intake plenum pan gasket that's causing the oil consumption and it will take out the catalytic converter as well if ignored, before pulling the intake check the compression on cylinder 6 to be sure it's the same as the other cylinders because those trucks were also prone to suffering from pounder valve seats that would cause misfires and if it is it's a good time to do the head when the intake is already out,
let me know what you find please as well
Old Apr 18, 2012 | 11:37 AM
  #8
Jimmijackson's Avatar
Mitchdakid
Oct 5, 2006 02:39 AM
tcase420
Sep 2, 2006 12:16 PM
KennyMac
Jul 9, 2006 11:36 AM
ken123
Jun 15, 2006 09:06 PM
stedown
Mar 7, 2006 04:35 PM
