worn brake pad indicator
Old Sep 12, 2007 | 02:09 PM
gunnerwoody's Avatar
Default worn brake pad indicator
Hi I am new here but, I have a problem that hopefully someone can answer. I replaced the pads on a 2001 jetta and the worn brake indicator light will not go off. I tried disconnecting the battery but that didn't work either. Any sugestions before I go to the stealership?
Old Sep 12, 2007 | 05:05 PM
tchristian's Avatar
Default RE: worn brake pad indicator
I'm not extremely familiar with the VW brakes, but on BMW's (which I am familiar with), if the brake wear sensor is triggered, you need to replace the sensor. It's not an expensive part and it clips into the caliper next to the pads. Check to see if that's what you have.
Old Sep 13, 2007 | 12:13 PM
Nope no sensors any other suggestions?
Old Sep 13, 2007 | 12:24 PM
tchristian's Avatar
I would think there has to be some kind of sensor in order for a light to be activated. Did you check both wheels? The BMW has a sensor on one side only.
Old Sep 13, 2007 | 11:31 PM
sdvw's Avatar
I work at City Volkswagen in San Diego California. I am in sales but I will ask a service advisor tomorrow about your problem. I'll post the solution as soon as I find out what needs to be done.
Scott
Old Sep 14, 2007 | 09:53 AM
moesauction!'s Avatar
Hello my vee dub freinds, i ahve found that replacing them with pads that arent oem , like pads from oreillys or auto zone the sensor wont read the aftermarket ones, common problem use only oem pads and it will clear the problem up.
Old Sep 14, 2007 | 09:57 PM
  #7
I appreciate the service help, I never heard of the OEM thing...
Old Sep 14, 2007 | 11:33 PM
  #8
marcia's Avatar
can someone help me with brake problem 73 VW bug
Marcia
maccavelli
Jul 28, 2009 09:46 AM
pungieEC
Aug 23, 2008 07:26 PM
PghBoy
Jul 1, 2008 11:56 PM
jlb532
May 7, 2007 10:46 PM
jlb532
May 7, 2007 10:43 PM
