oil pan and coolant
Old Apr 8, 2008 | 08:18 PM
TerraBaby's Avatar
Default oil pan and coolant
so my 2000 vr6 is leaking coolant and my oil pan is busted where can i find cheap parts and does anyone else find themselves bottoming out often? and is leaking coolant something that happens to people with this car?
Old Apr 9, 2008 | 08:50 AM
racerx002's Avatar
Default RE: oil pan and coolant
For the oil pan you might try germanautodismantlers.com or specializedgerman.com for a used one. Or you can use some J.B. Weld and patch it if the crack is small enough. I don't know about the bottoming out I have a 2.0L engine. Where is the coolant leaking at?
Old Apr 10, 2008 | 02:25 PM
bagel's Avatar
I got a pan from a junk yard cause mine bottomed out on the pan, too. I had leaking coolant coming from the heater core lines, the tee fitting that went to the core and the thermostat housing. I think about $80
ndpndntz
Jan 21, 2009 10:36 AM
ladybug2000
Aug 28, 2007 06:06 PM
BugDaddy
May 30, 2007 06:55 PM
1dolrshrt
Jan 25, 2007 01:56 AM
Huffer
Oct 17, 2006 02:47 AM
