oil pan and coolant
so my 2000 vr6 is leaking coolant and my oil pan is busted where can i find cheap parts and does anyone else find themselves bottoming out often? and is leaking coolant something that happens to people with this car?
RE: oil pan and coolant
For the oil pan you might try germanautodismantlers.com or specializedgerman.com for a used one. Or you can use some J.B. Weld and patch it if the crack is small enough. I don't know about the bottoming out I have a 2.0L engine. Where is the coolant leaking at?
I got a pan from a junk yard cause mine bottomed out on the pan, too. I had leaking coolant coming from the heater core lines, the tee fitting that went to the core and the thermostat housing. I think about $80
