no power brakes
Old Apr 24, 2008 | 09:03 PM
woody1's Avatar
Member
Default no power brakes
today my 2001 jetta lost power brakes for a short time. i was pulling out of a parking spot in reverse and found that the brake assisthad stopped working. i checked the brake fluid it was full and did not notice a vacume leak(although i was fairly upset and was rushed to punch back infor lunch). after work i went out to see if i could drive it home. i noticed that as the engine rpms rasied the system charged butwould not recharge at lower rpms after pumping the pedel 2 or 3 times. however, after 5or10min of this, the system started working normaly.i decided to drive it home and it did not happen the whole ride home. i was thinking the power booster, but if the diaphragm was damaged i would think the that the assist would be lost pemanently but i dont know for sure. not tomention i did not check the vacume lines well.
any ideas
Old Apr 25, 2008 | 05:07 PM
bagel's Avatar
Default RE: no power brakes
what did the pedal feel like? If it's real hard then you booster would be losing vacuum. Check your fluid again after you pump the brakes a few times, if it drops then you have a leak somewhere. I'm really trying to rack my brain on this, I kinda know the system but for it to loose power and then come back is kinda weird....
Old Apr 26, 2008 | 01:39 PM
woody1's Avatar
Member
the fluids are full.. the pedel was stiff like when the car is off and u hit the brakes. am i right to think if it was the booster the power brakes would go out completly.
Old Apr 26, 2008 | 01:48 PM
bagel's Avatar
Yea I would, not sure but it would be the booster.
Old Apr 26, 2008 | 03:09 PM
woody1's Avatar
Member
thare isent anything other than the booster and the lines right. if any thing went wrongit would be one ofthe 2 right
Old Apr 27, 2008 | 11:40 AM
woody1's Avatar
Member
ok id like to reword the symtoms of the brakes. after driving the car more often if notice that the assist is only acting up during the first startup after siting for awile. and its not thatthay go out completly but dont rebuild presser fast enough. but gose away after a few min..
Old Apr 27, 2008 | 12:14 PM
  #7
bagel's Avatar
I still say have the vacuum booster checked out. Maybe there's a line that's messed up
moe.ron
Dec 2, 2006 01:24 PM
danlewi
Jul 14, 2006 03:24 PM
klugej
Jul 11, 2006 12:01 PM
klugej
May 11, 2006 01:23 PM
fdunne
Jan 13, 2006 12:35 AM
