Brakes
Old Jan 12, 2006 | 09:53 AM
fdunne's Avatar
Default Brakes
Hi all,
Taking my car to garage today but just thought I would ask if anybody could tell me if doing anything wrong
The problem is my brakes are not responding fully, when I press my brake pedal, it will go almost all the way down to the floor before starting to brake
I had my brake discs check last week before the problem arose and they said they were fine
Yesterday the Brake Fluid light came on saying top up, so I thought Ill top up tommorw on my lunch at work
Driving to work this morning and no Brake Fluid Light warning
Half way to work after using my brakes a bit and felt responsive enough and okay
Next thing, bang, Pedal didnt respond until Pedal was nearly to the floor
So, got some brake fluid today and topped full up to the MAX
Pumped the Brakes a bit and felt much more reaponsive
Started engine, pressed brake pedal and same thing, pedal lost all pressure and stright to the floor nearly
My question is, do I have to wait a certain amount of time for the Brake fluid to kick in, or do I need to do anything else like pump the brake pedal for a bit
Any help would be great
Cheers
Old Jan 13, 2006 | 12:35 AM
89 jetta carat's Avatar
Default RE: Brakes
i would have the brake master cylinder changed. whenever the brakes go to the floor its a pressure problem. so that means either you have an open brake line or your master cylinder is no good
moe.ron
Dec 2, 2006 01:24 PM
danlewi
Jul 14, 2006 03:24 PM
klugej
Jul 11, 2006 12:01 PM
T Free
May 30, 2006 06:10 PM
klugej
May 11, 2006 01:23 PM
