Golf V 2.0 TDI 170 – Loss of Power + Flashing Glow Plug Light Despite New Turbo/Waste
Old Dec 4, 2025 | 05:39 AM
nishaanewar's Avatar
Exclamation Golf V 2.0 TDI 170 – Loss of Power + Flashing Glow Plug Light Despite New Turbo/Waste
Hi everyone,
I have a Volkswagen Golf V 2.0 TDI 170 (DSG), model year 2008, and I'm dealing with a very annoying issue that I can't solve.
🔧 The Problem:
The car drives normally when I'm cruising, but as soon as I press hard on the accelerator, especially under load, the glow plug light (flashing) appears on the dashboard, and the car goes into limp mode with a big loss of power.
This usually happens:
  • When I accelerate hard
  • When Sport mode is ON
  • When A/C is ON
  • Or at higher speeds around 120–130 km/h
Sometimes it happens after 1 km of hard acceleration, sometimes after only 200–300 meters.
🔧 Parts already replaced / modifications made:
  • Brand new Turbo (complete unit)
  • Brand new Wastegate
  • DPF (FAP) deleted completely (software + physically removed)
  • Catalytic converter emptied inside
  • EGR deleted in the software and blocked mechanically
Despite all of this, the issue is still exactly the same.
⚠️ Additional Notes:
The problem only appears under load or when the engine is pushed hard.
Driving gently = no issues at all.
❓ My question to the community:
Since Turbo, Wastegate, EGR, DPF, and Catalytic converter are all new or deleted properly, what else could cause this behavior?
What should I check next?
  • MAP sensor (boost pressure sensor)?
  • N75 valve (boost control electrovalve)?
  • Boost sensor / pressure sensor?
  • Fuel rail pressure sensor?
  • Fuel pump not delivering enough pressure under load?
  • Or maybe a bad software delete of FAP/EGR/CAT causing incorrect boost/fuel values?
I’d really appreciate any recommendations before I start replacing sensors blindly.
Thanks a lot 🙏
Radu Rx
Sep 26, 2021 04:05 PM
hpcrazy
Sep 2, 2014 09:16 PM
kvwgrindle
Nov 8, 2011 04:26 PM
elisetbk
Dec 28, 2010 03:42 PM
NorthVanBioTDI
Feb 5, 2010 08:06 PM
