golf -98 light issues
Old Oct 6, 2011 | 02:16 AM
Gewing4's Avatar
Member
Default golf -98 light issues
Hello,
Problem: Only right side lamp works in parking light and high beam mode (not in driving light mode). Where could I find relay diagram?
Left lamp doesn't work at all. Altitude changer works.
Not long ago the automatic light did not switch on when car was started, but when tampering with headlight switch at the dashboard, both light started to work.
Then suddenly when changing to parklight mode both lights shut down (bulbs did not break). I got right headlight to work when switching the control panel.
Both lamps has been changed and fuses are ok. Maybe the problem is in relay or in headlight switch controller on dashboard. Where could I find relay diagram for this model, that would be the cheapest way to start fixing I guess.
MK4VW
May 24, 2012 04:56 AM
Feb 21, 2011 12:05 AM
lilplague44
May 1, 2009 03:04 AM
callmecheez
Apr 18, 2007 01:23 PM
eirual
Apr 11, 2007 05:26 PM
