VWF Help & Suggestion Center Need help with VWF? Ask. Have a suggestion to better VWF? Tell us here.
water pump
Old May 20, 2006 | 12:18 AM
blujet's Avatar
Default water pump
I think my waterpump just went out it started overheating and leaking antifreeze. How hard is it to change the waterpump on a '02 jetta 1.8T. Are there any other possibilities of what it could be?
Old Jun 8, 2006 | 05:54 PM
stv fox's Avatar
Default RE: water pump
get a book on your car or go to the library and photocopy what you need if the pump is leaking coolant it is toast you may as well change hoses and the thermastat and flush the system with a good rad flush product do this before you change anything so you will start clean with the new parts be aware what you do with the old coolant!!!!
Daniellem3176
Apr 25, 2009 08:41 PM
bdh128
Jul 15, 2007 02:34 PM
baldy_54
Apr 9, 2007 04:25 PM
Shauggy
Jan 3, 2007 08:41 PM
Ralphnet
Feb 7, 2006 03:47 AM
