water pump
I think my waterpump just went out it started overheating and leaking antifreeze. How hard is it to change the waterpump on a '02 jetta 1.8T. Are there any other possibilities of what it could be?
RE: water pump
get a book on your car or go to the library and photocopy what you need if the pump is leaking coolant it is toast you may as well change hoses and the thermastat and flush the system with a good rad flush product do this before you change anything so you will start clean with the new parts be aware what you do with the old coolant!!!!
