"Antenna" "A problem has occurred"
Old Mar 6, 2020 | 01:43 PM
Jfvt2011's Avatar
Default "Antenna" "A problem has occurred"
I purchased a used 2011 Tiguan SE from a dealer (not a Volkswagen dealer) with a known problem with the antenna. The car is white with a black antenna and someone had caulked the base with white caulking and did a poor job. The dealer replaced it and it looks perfect. The dealer did mention there was a wire that was not connected and they connected it. I got all FM stations I tried since that is mostly all I listen too but later discovered I have no AM. Also the Sirius didn’t connect but figured it was because I didn’t subscribe. We got a letter from Sirius saying our free trial will expire soon and after talking to Sirius they extended it another three months and sent an activation code. When I tried Sirius a message came up with the title "antenna" followed by "a problem has occurred" and it did not connect. I talked to the dealer I bought from and they are checking in to see what they can do.
In the meantime what suggestions are out there as to what to do?
Is this something I can fix myself?
How do I remove the antenna and see what’s going on?
Thanks!
After
Before - oops didn't realize is in line with a telephone pole
Old Mar 7, 2020 | 06:57 AM
Post approved.
Jan 18, 2011 12:14 AM
Mutt96
Jun 15, 2009 11:34 AM
jetta jack
Nov 29, 2007 09:55 AM
jetta jack
Nov 19, 2007 02:03 PM
mork
Feb 12, 2007 01:11 AM
