Car wouldn’t go in gear, and now is jammed in gear.
Old 09-24-2017, 10:43 AM
Joshua Purchase's Avatar
Default Car wouldn’t go in gear, and now is jammed in gear.
So car has been perfectly fine no problems with clutch or gearbox. Started it up fine today and went to put it into gear and it wouldn’t go in any gears at all, went to put in in reverse and it wouldn’t go in would only grind. Turns the car off got my dad to have a look and he has jammed it into gear now and it won’t budge out. If I try to start the car with the clutch down it will just stall. Does anyone know what’s wrong?
thanks
Old 09-25-2017, 06:34 AM
You don't say which model though you have posted in Polo. What year, engine?
Get the clutch hydraulics checked out.
mike74055
06-03-2011 02:25 PM
mightymick
04-05-2011 06:38 PM
GrilledCheese
12-18-2007 12:13 PM
colin_21
07-22-2007 02:32 PM
jaminondatguitar
04-23-2006 09:38 PM
Quick Reply: Car wouldn’t go in gear, and now is jammed in gear.
