Need Help in NJ
I'm a Factory Trained, Registered Expert Technician and ASE Certified looking for side work. Minor/Major Services, Brakes, Exhaust, Suspension, Timing Belts, Clutches, Engine Swaps, you name it. VAGCOM recoding/MODS... I have the experience, resources, and knowledge to do it all. I offer mobile Diagnosis, VAGCOM MODS, and minor repairs in the Monmouth and Ocean County area. Check out my photo albums. If you need any VeeDub work done shoot me a call (732) 691-2335 or email jaautowerks@gmail.com
Thanks,
John Andryszewski
JA Autowerks
(732) 691-2335
Thanks,
John Andryszewski
JA Autowerks
(732) 691-2335
hi, i was wondering if i could get some advice from you to get a problem fixed on my 98 jetta. concerning tht lame secondary inj. system. (code P0411). I already tried doing lots of things, but the code won't go away...
Thanks
Vladimir
Thanks
Vladimir
I did all that. Even jumped the Air pump, directly from the battery and it works. I replaced the combi valve, got new rubber hoses and even that plastic tube that goes from the air pump to the combi valve. When is very cold outside, the air pump won't start. Sometimes when i let it idle that thing comes on like 3 times very quick and the shuts down. All i can think is that it might be the relay. Is there any way to test the relay??
Santa Albert
Sep 9, 2013 01:24 PM
beardo265
May 12, 2011 02:40 AM
