Cooling System problems
Old 09-06-2008 | 04:47 PM
mls5425's Avatar
Default Cooling System problems
2004 1.8 Passat.
Recently, I got the "STOP" message, followed by the "check coolant message". I checked the coolant, and it was a thick baby poop brown sludge. Got the system flushed and a few days later, it happened again. I took it to my mechanic, the water pump, being made out of plastic, was broken. So I had the timing belt, water pump and serpentine belts all replaced. The system was flushed again. 3 days later, the coolant is back to the sludge and got the "STOP" message again. Is there any other explanations for this? Thanks for the help.
Old 09-06-2008 | 06:43 PM
Jrailer's Avatar
Default RE: Cooling System problems
oil cooler is bad letting oil in the coolant oil cooler above filter
the pump would not have let oil in
replace cooler and you will need to flush it many times
Old 09-06-2008 | 10:29 PM
mls5425's Avatar
Is this an expensive part? I am not familiar with oil coolers. Thanks for the info Jrailer. I will take this to my mechanic and hopefully all will be good after this. What is your opinion onthis VW model with 100k miles with regular maintenance and new timing belts, serpentine belts and new water pump. The car physically is in super shape and this is the only major problem I have had with it. Do these cars hold up fairly well compared to mostafter 100,000 plus miles. Thanks again.
Old 09-06-2008 | 11:54 PM
Jrailer's Avatar
oil cooler is very cheap
oil pumps can be a big problem on the 1.8
are you runing synthdic oil ?
Old 09-07-2008 | 01:52 PM
mls5425's Avatar
Should I be running a synthetic oil? I will have to check that out.
Old 09-07-2008 | 02:22 PM
Jrailer's Avatar
yes
siwy
08-27-2007 11:26 PM
jeepwillies
07-13-2007 06:04 PM
Sagittare
05-12-2007 10:08 PM
J_Dada
10-01-2006 05:29 PM
Wild Bill
08-26-2006 04:48 PM
Quick Reply: Cooling System problems
