2010 Passat wagon brake pedal dropping to the floor under pressure
Old May 28, 2020 | 12:58 AM
Mrpepiche's Avatar
Default 2010 Passat wagon brake pedal dropping to the floor under pressure
Hi please help I'm having a hard time figure this one out
Problem : brake pedal went soft 2days afters a brake pads change. The pedal is going all the way to the floor under pressure and is very soft on first application but only when the engine is on
What i did : 1: change pads with vcds procedure and test for rear electric caliper
2: my first diagnostic was a bad master cylinder so i replaced it whit a new one
3: bled the brake 9 times twice with a vaccum pump and bleed the abs valve using vcds procedure twice all new brake oil
4: check vaccum leak with vaccum gauge vaccum is at 27
5: check for leaks every caliper, abs module, master cylinder all hoses brake line chevked 10 times there is none
6: change all caliper one by one (used caliper from a friend car)that changed nothing
7: changed all brake hoses just n case no result
8: checked brake booster vaccum by removing the hose pedal goes very hard just like when the car is turned off
9: checked the brake booster hose for any crack there is none when i disconnected the hose i heard that there was indeed vaccum building in the booster
10: no abs light , no code stored
Anyone has any idea I'm thinking this might be the abs module but there is no code or abs light and seeing the price of that thing I'm very reluctant to change it without beeing 100% sure it is my problem
Any advice is welcome I'm very lost here
Old May 28, 2020 | 08:17 AM
Is that a genuine VCDS cable or a cheap Chinese cloned cable?
Post approved.
Old May 28, 2020 | 12:18 PM
Mrpepiche's Avatar
Didnt knew i had to go thru a new member process here sorry if i am skipping step here thing is the car is broken now and im in a bit of a rush to fix it. I will make sure to post the solving for this problem and try to help others now that i found this forum i have good knowledge i am sure i can help many
Thanks for reply i used a Hex-v2 vcds cable for every vcds procedure on this car
Old May 29, 2020 | 09:31 AM
That isn't an easy question to answer on a forum.
The brake pedal dropping to the floor I would say the brake master cylinder has a problem but you have changed that.
Did you follow the correct procedure for bleeding ABS brakes with VCDS?
huyuhy
Jun 1, 2011 04:53 AM
Mar 17, 2011 12:51 AM
CTranny92
Feb 11, 2010 12:06 PM
jettagirl
Feb 10, 2008 09:54 PM
fdunne
Jan 13, 2006 12:35 AM
