1999 V6 Passat ABS/Brake Light
Old Aug 16, 2011 | 04:25 AM
piyush123's Avatar
Default 1999 V6 Passat ABS/Brake Light
My Passat (116,000 mi.) has been flashing the ABS, BRAKE and OIL LAMP light warnings on my dash intermittently, beeping for 3 beeps (2-3 times a day, slow or fast speeds, using the brakes or not using the brakes) and at the same time the tachometer does not work. The shop I took it to said no codes were stored.
Do I have a bad instrument panel cluster? Are they some ABS pin connections I need to change? How would these affect the tachometer and oil pressure lamp coming on? Should I buy a new instrument panel cluster? Can I install it myself? Where do I buy them and can I change it out myself and with what tools?
Thanks.
huyuhy
May 4, 2011 04:26 AM
euro_turbo
Jun 9, 2010 08:21 PM
02 WS6 TA
Feb 16, 2010 01:52 PM
bill142
Jun 15, 2008 10:50 AM
surf3184
Sep 18, 2007 09:04 PM
