07 passat problems solved
Old Jun 2, 2009 | 11:39 AM
trucky24's Avatar
Default 07 passat problems solved
Had three issues with my passat. car has 27000 miles on it. Just wanted to pass on the info. My emergency brake switch went bad. Covered by warranty. Funky smell coming out of the vents when I used the A/C. They said they would inject a chemical in the system to clean the vents and replace the cabin air filter, they had a TSB on the issue. And when I turned the rear defrost switch on the radio would get static. The said the rear glass needs replaced cause the defrost in the glass had a short or bad connection. Luckily was covered under warranty and the dealer was nice as pie about it.
myjetta
Jul 7, 2011 10:23 AM
2004Passat
Dec 18, 2007 11:01 PM
nops
Nov 9, 2007 01:27 AM
alienkidmj12
Jun 28, 2007 05:33 AM
emily
Nov 26, 2006 05:40 PM
