no power to fuel plump
Old Jun 18, 2011 | 12:02 PM
cldcld's Avatar
Default no power to fuel plump
1998 Jetta wouldn't start, with key turned no fuel pump running, checked fues 18 and it was good, fuel pump relay was clicking when I turned key, so that should be good, so I opened the fuel pump and check for power with a test light and had none, ran jumper wire from battery ground to pump worked, so I ran a ground wire from battery to pump and turned key and no power so the ground is not problem, is their a shut-off switch stopping power to battery
mcarnes28
Jul 3, 2013 06:41 AM
discarn8
Oct 23, 2012 04:04 AM
HI_C92806
May 3, 2012 02:41 AM
airborne21
Dec 1, 2007 10:50 AM
pwell61
Jan 12, 2007 09:10 PM
