MK4 electrical problem
Old Jul 11, 2016 | 03:17 PM
Jmadcat22's Avatar
Default MK4 electrical problem
I own a 2000 VW Jetta 2.0 5 speed. when i bought the car it has a dead man switch hooked up straight to the battery. the dash stays on the tripometer and clock does not turn off when i turn the car off. Which is killing the battery in a day. i have to use the dead man switch to stop it from draining the battery. what can be causing this?
Old Jul 12, 2016 | 07:38 AM
The dead man switch isn't a good idea as all settings are set to default. You need to find this battery drain which is a common thing CAN Bus, which you can Google.
File Type: gif
Old Jul 14, 2016 | 04:35 PM
Jmadcat22's Avatar
The dealership wants to charge me $200 an hour to scan it. i have worked for several dealerships before and know how it goes with shops. I actually talked to the technicians and they have never encountered this problem with any jetta.
Old Jul 15, 2016 | 05:47 AM
You don't say where you live?
In the UK dealers charge £60 for a diagnostic scan which doesn't take an hour.
Your saying $200 for a dealer scan so I assume you could be in USA. AutoZone will do a free scan in the hope you buy something of the.
Old Jul 17, 2016 | 04:39 PM
Jmadcat22's Avatar
Sorry about that i do live in the USA. i scanned the computer and the only code is a misfire i fixed. i ran through the wiring diagram and solved the problem.
Old Feb 16, 2018 | 09:11 AM
IED1TB2's Avatar
Question ELECTRICAL wiring diagram
Can you please share what the wiring problem was?
Old Feb 17, 2018 | 07:13 AM
  #7
gsxr1100
Feb 10, 2011 07:18 PM
Jay2002
Jan 28, 2008 08:24 AM
beat cj
Mar 6, 2007 02:54 AM
ezpcent
Jul 6, 2006 09:52 PM
Giovanni
Jul 5, 2006 11:50 PM
