KEY FOB alarm not working
Old Jan 28, 2009 | 06:30 PM
nbark99jetta's Avatar
Default KEY FOB alarm not working
This is driving me NUTS!!! The batteries died in my fobs.I replaced them but the fobs still not working.
I have looked at alot of forum's about this topic and havn't gotten anywere.
I have heard alot of different ways to reprogram the fob.
The latest one is
1: take the key that needs programmed put it in the ignition and turn it on
2: roll driver window down and insert valet key into door lock.
3: turn valet key to the lock position on the door lock and hold it there
4: press the unlock button on the key in the ignition and hold for 2 seconds.
release then press unlock again and hold for another 2 seconds.
You should hear the horn beep. Then that key will be programmed.
THIS DIDN'T WORK.
Also heard that you can just put the key into the driver door lock and press/hold either
lock or unlock button for 20-30 seconds and that will program it.. Guess what.
IT DIDN'T WORK!!!!!!!
DOES ANYONE HAVE ANY SUGGESTIONS
Old Jan 29, 2009 | 10:16 AM
racerx002's Avatar
Default RE: KEY FOB alarm not working
Were they working at some point? You can try resetting your ecu by disconnecting your battery cables and touching them together for about a minute. If that doesn't work you'll have to take them to the dealer to have them programmed.
Old Jan 31, 2009 | 09:31 AM
yea, they were working before. I thought it may be the batteries. I changed the batteries but still nothing... I'll try to reset the cpu. I don't understand touchinghow tochingpos/neg cables together will reset it but i'll try it..AndYES i'll disco them from the battery before I do it....
Old Jan 31, 2009 | 11:35 AM
racerx002's Avatar
The ecu keeps residual power in it and when you touch the cables together it drains the power from it.
pdubs
Jun 10, 2013 03:18 PM
VDubbinVW
Dec 11, 2011 10:31 PM
GregMorris
Sep 20, 2010 08:40 PM
adamoliver
Dec 2, 2007 02:02 PM
martyndarkly
Jan 10, 2007 12:45 PM
