Front passenger interior dome light stays on & button controls other interior lights
Old Jan 6, 2018 | 12:19 AM
thorxes's Avatar
Default Front passenger interior dome light stays on & button controls other interior lights
Ok so I just bought a 2010 Jetta 2.5L. Found out the interior lights didn't work - visor lights, front and rear dome lights. Figured out that it was the fuse.
When I put the fuse in - the front right passenger dome light stays on. I checked the open door light switch, and no matter what (of the 3) positions it's in, the front right passenger light stays on. If I hit the button for it, the OTHER interior dome lights (front driver and rear dome lights) turn on. If I hit it again, the other dome lights turn off. Using those other switches independently works their respective lights properly. But nothing I do (other than pulling the fuse) will turn the front right passenger dome light off.
Any ideas? I've thought of just removing the light bulb for the front right passenger dome light - but I'm not sure if it would still continue to draw power from the battery or not. Ideally I'd like it to work properly.
Any suggestions, videos, or help is appreciated.
Old Jan 6, 2018 | 08:22 AM
Do you have the correct fuse & relay layout diagram?
Old Jan 6, 2018 | 11:14 PM
thorxes's Avatar
Finally figured out the issue.
You need to take the dome light fixture off. On the ceiling above the fixture, there was a torque screw that had come loose and was touching the metal backplate of the dome fixture. I tightened up this screw and it all worked as intended.
Found the answer on a VW Golf forum.
Quixotegut
Dec 8, 2010 06:05 PM
jrusk
Oct 26, 2009 09:01 PM
loki
Mar 11, 2008 08:04 PM
remission
Oct 11, 2007 07:38 AM
markde74
Mar 19, 2007 02:33 PM
