I have a 2009 Jetta 2.0T (CBFA) (105,000 miles) 6 speed manual transmission and I have dreaded check engine lights that I can’t get off. I had the whole engine out and replaced all seals and gaskets throughout the engine within the past couple weeks. These codes weren’t here before I tore engine and tranny out. I replaced quite a bit of stuff while it was apart too. I have a picture of all the things that were done while the engine and tranny was out. Any help is greatly appreciated!
