Check Engine Light That Won’t Go Away!! Help!!
Thank you for the add!
I have a 2009 Jetta 2.0T (CBFA) (105,000 miles) 6 speed manual transmission and I have dreaded check engine lights that I can’t get off. I had the whole engine out and replaced all seals and gaskets throughout the engine within the past couple weeks. These codes weren’t here before I tore engine and tranny out. I replaced quite a bit of stuff while it was apart too. I have a picture of all the things that were done while the engine and tranny was out. Any help is greatly appreciated! https://cimg6.ibsrv.net/gimg/volkswa...4b8a6afadb.png https://cimg9.ibsrv.net/gimg/volkswa...4dce6ca348.png |
Default Welcome to Volkswagen Forum - Rules & Recommendations Manufacturer: VW, Date(s) Used: 04/2008-10/2010, Model: Jetta, Engine Code: CBFA, 147Kw, 200PS, 2.0 Ltr, 4 Cyls, Remarks: Turbo Fuel Stratified Injection (TFSI) Bosch Motronic MED 17.1 Chain You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out. Not a generic scanner. Thread approved. |
