97 jetta gt tranny/speedo/heat problem
Old Jan 12, 2017 | 08:16 PM
Josh Ray Desbois's Avatar
Default 97 jetta gt tranny/speedo/heat problem
My jetta recently started shifting up (I assume) or goes limp (no power) when the temp sensor reads 90 at this time the speedo also goes wild and jumps around. When I crank the heat the problem goes away as the temp sensor reading drops from 90.
No issues when cold or under 90 degrees. Need help desperately as I drive 160k a day for work and can't afford a new car.
Old Jan 13, 2017 | 05:08 AM
Post moved to correct section.
Old Jan 13, 2017 | 06:21 AM
There's no check engine light and the guy I had try his scanner came up with nothing? I know it's an odd problem.
bcatt
Oct 21, 2011 11:03 AM
Feb 5, 2011 02:18 AM
95Jetta
Jan 25, 2009 09:47 AM
northerngreaser
May 22, 2008 09:01 AM
