97 jetta gt tranny/speedo/heat problem
My jetta recently started shifting up (I assume) or goes limp (no power) when the temp sensor reads 90 at this time the speedo also goes wild and jumps around. When I crank the heat the problem goes away as the temp sensor reading drops from 90.
No issues when cold or under 90 degrees. Need help desperately as I drive 160k a day for work and can't afford a new car. |
Post moved to correct section. ;) |
Originally Posted by Keithuk
(Post 63841)
