94 Jetta won't start Need good help
Old Aug 27, 2008 | 08:02 PM
Jo Ved's Avatar
Default 94 Jetta won't start Need good help
wassup y'all, i got a 94 jetta that I need some real deep help with, y'all might be able to help might not I don't know but I need this car runnin & this the last thing I thought of to be able to try to fix it, so, here's the thing. the car's been sittin for about a year and a half now, it was sittin for about a year cause the clutch was gone and we ain't had money to take it to the shop, so a friend of mines that knew how to do it helped me change the clutch on it, so the car then had a clutch, but now for some reason, the car don't work, it does not want to crank up, won't ever turnover. we had a mechanic look at it (which he ain't too good with electrical stuff) and after he got done looking at it he said that we needed a new cpu, but since we already know he wasn't good with that didn't really trust his word, but he did tell us that there is no power going to anything, the motor, the starter, he said nothing was getting power, I checked it out today again and took some pictures so y'all could help me out further, there was power going to the starter on the positive/alternator part, not on the ground, and from the pictures let me know if the starter is even hooked up right. please go to this link below and let me know what u think.
http://s479.photobucket.com/albums/rr152/joved/
Old Aug 27, 2008 | 08:06 PM
Jrailer's Avatar
Default RE: 94 Jetta won't start Need good help
does it even crank over??
you know you have to push the clutch in for the starter to work
check your ground wire it looks like you have it done up on the starter bolt is it tight
Old Aug 27, 2008 | 08:17 PM
Jo Ved's Avatar
oh yeh I know, I do push the clutch in, but nothing bro, it doesn't to anything, but yeh the starter wire is tight, it's in there
Old Aug 27, 2008 | 10:11 PM
bagel's Avatar
do you get dash lights? interior lights on? Follow your ground wire from the battery down to the starter, you may a rotted wire somewhere. Remember, the car sat for over a year..through what 2 winters? hot summer days? there's prolly some busted wires in there somewhere. Just follow that ground wire down from the battery and see if you see corroding or anything wrong with the wires.
Old Aug 27, 2008 | 10:36 PM
Jo Ved's Avatar
aight, ima check that tommorow mornin, right now it's night time over here but ima post it up tommorow, but yes, whenever put the jumper on, I get dash lights, the corny music plays, i ain't tried turnin nothin else on but there is power to the car whenever i put in the key or got the jumper box on it.
mail4ajc
Apr 15, 2022 06:09 PM
wearyourtruth
Jan 2, 2009 01:29 PM
Treylin
Aug 16, 2007 01:20 PM
tokyorose
Aug 8, 2006 09:39 AM
CamGold
Jul 21, 2006 12:22 PM
