brake lights
Old Aug 26, 2008 | 08:41 AM
giogonz's Avatar
Default brake lights
My brake lights don't turn on when i hit the brakes. I checked the fuseit's good,I checked the bulbs they seem fine. Does anyone know what it could be?
Old Aug 26, 2008 | 08:43 AM
Jrailer's Avatar
Default RE: brake lights
recall
breke lt switch
Old Aug 26, 2008 | 02:28 PM
giogonz's Avatar
Thanks jrailer I changed the switch. Now the brake lights will not turn off even when car is off. I had to pull the fuse.[:@]
Old Aug 26, 2008 | 07:47 PM
bagel's Avatar
did you wire it correctly?
Old Aug 26, 2008 | 09:16 PM
Jrailer's Avatar
ya those switches ar a bugger to get adjusted properly
Old Aug 27, 2008 | 11:32 PM
00Jetta_trs's Avatar
I had the same problem.
acutally mine still does it but only when i turn my circulation button off.
Im thinking that some where in the wiring that the circulation button wire and the emergency brake light wire are crossing which is causing the short.
huyuhy
Oct 8, 2011 03:44 AM
96 jette guy
Jun 14, 2010 05:02 PM
NY_VW
Jan 19, 2006 09:22 PM
shana
Nov 28, 2005 03:03 PM
rossiross
Jul 26, 2005 08:53 PM
