2011 Jetta SE passenger floor vents blow cold air
Old Dec 30, 2017 | 02:32 PM
Erbgrace219's Avatar
Default 2011 Jetta SE passenger floor vents blow cold air
I have the base model 2011 Jetta SE (2.5). Got my car in March so only recently did I start to use the heat, it works great throughout my entire car except the passenger side floor vents produce no heat whatsoever, it is cold (freezing) air. If you turn the heat on max and set it to feet no matter how long you let it run it never warms up, not at all. If you blast it then the cold air just comes out faster/more.
Turning the air recirculation on helps, but it still does not produce heat, it just lessens the amount of cold air blowing on your feet. And I can’t just keep the air recirc on because it fogs up my windows. The car has no other problems and the heat works great in all the other vents.
Any idea what this is and how I can fix it?
Old Dec 31, 2017 | 07:44 AM
scottyboy24
Jan 25, 2017 10:21 PM
davewillner
Sep 6, 2008 12:52 PM
PurduePete
Oct 8, 2007 03:13 PM
EricC
Nov 1, 2006 06:46 AM
hvnitro006
Sep 26, 2006 12:15 PM
