07 Jetta wont shift out of park i screwed up
Old Dec 2, 2016 | 08:33 PM
bstoehr's Avatar
Exclamation 07 Jetta wont shift out of park i screwed up
I have an 07 jetta. Today i installed a new radio and tried to install a backup camera. After installing the radio i took it for a ride and it worked and shifted fine. afterwards While installing the backup camera one of the reverse lights stopped working. This was not the reverse light i tapped into. This was then followed by it not shifting out of park. I dont believe its the break switch as when i press the break the lights work. Please help me with the problem. I bought the car a month ago and it has been running fine up in till this point.
Old Dec 3, 2016 | 07:02 AM
Which radio did you fit an OEM or not?
Locked in park is a problem you can Google. The brake light switch is a problem but you say they work as normal.
Did you code the radio with VAG-COM\VCDS?
You need to scan your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing.
Old Dec 3, 2016 | 08:56 AM
whitey ford's Avatar
Check for codes if possible. Check the wiring going to transmission, it may have come loose, there is a TSB about that. More then likely you have a faulty brake light switch. To release the shifter from park you will need to take the shifter apart where the shifter handle is and the use a flat head screwdriver to release the shift lock solenoid in the shifter assembly.
Ernest Pardue
Sep 17, 2019 07:54 AM
Paul Armbrust
Nov 14, 2015 10:44 AM
GolfCart
Feb 9, 2007 10:14 PM
ojready
May 18, 2006 04:15 PM
Kiljosh
Mar 23, 2006 07:55 PM
