07 Jetta wont shift out of park i screwed up
I have an 07 jetta. Today i installed a new radio and tried to install a backup camera. After installing the radio i took it for a ride and it worked and shifted fine. afterwards While installing the backup camera one of the reverse lights stopped working. This was not the reverse light i tapped into. This was then followed by it not shifting out of park. I dont believe its the break switch as when i press the break the lights work. Please help me with the problem. I bought the car a month ago and it has been running fine up in till this point.
Which radio did you fit an OEM or not?
Locked in park is a problem you can Google. The brake light switch is a problem but you say they work as normal. Did you code the radio with VAG-COM\VCDS? You need to scan your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing. https://volkswagenforum.com/forum/ne...gnature-34185/ |
Originally Posted by bstoehr
(Post 63782)
