How much boost is too much?
Old Aug 9, 2009 | 06:29 PM
rdhoffmann's Avatar
Default How much boost is too much?
How much boost is too much on a 2002 GTI 1.8L Turbo.
I'm currently running 8lbs.
Can the car take more?
Old Aug 10, 2009 | 07:10 AM
vw_tech30114's Avatar
wouldnt risk it. would cause too many problems mechanicly and thru the computer. the computer can detect when you turn the boost up and will not like that and start to play up. and worst case sinario could stuff the turbo up.
Old Aug 13, 2009 | 10:13 AM
jonesy100's Avatar
yeh its probably slightly too risky. You might upset the handling also
Old Aug 27, 2009 | 01:32 AM
rdhoffmann's Avatar
Yeeah... sound safer just to leave it at 8.. Thanks guys
Old Sep 4, 2009 | 01:49 PM
dub4502's Avatar
you could always get a reflashed ecu and run plenty more boost, i got uni 1+ and spike over 20 psi, no problems that I have seen yet except for a few kicked ignition packs, due too not regapping plugs
Old Sep 5, 2009 | 05:23 PM
UberSchnell's Avatar
Keep it at 8lbs and you will be driving the car much longer.
Turn it up, and sure it will run it. But it will severely reduce the life of the motor.
ovencecract
Apr 1, 2011 08:37 AM
dalpod74
Sep 7, 2007 06:28 PM
donfish06
Jul 12, 2007 01:15 AM
NoobGTI07
Dec 6, 2006 08:47 AM
freekie_deaky
Dec 30, 2005 06:18 PM
