1.8L Gas, oil filter housing removal
Old Jan 27, 2008 | 07:42 PM
CabrioComet's Avatar
Default 1.8L Gas, oil filter housing removal
Hi, I'm new here and hoping you can help me. My '89 Cabriolet (1.8L gas motor) just lost most of it's oil and after pushing it home (fortunately this happened a block away), I added some more oil and put a drain pan under it and fired it up. It's hemoraging out of the oil filter housing at the seam between the circular oil press. sending unit and the square base, just on top of where the filter screws into the housing.
I am moving and need this since this is to get to workmy only running car. So I drained the oil and pulled the filter off. There are three bolts holding this in place, one on top, two underneath. Removing the top one is not problem, regular hex head bolt. However, the bottom two are round and look to be allen type bolts. The problem is even with the filter removed I can not get a tool in there to remove them, the square base of the housing is in the way. How in the heck do you get this off? I looked through my Haynes manual, and not surprisingly, no mention of this. Also searched the internet and couldn't find anything there either. So hopefully one of you can help me.
Thanks
Old Feb 4, 2008 | 08:27 PM
Smokin Dog's Avatar
Default RE: 1.8L Gas, oil filter housing removal
Those allen type bolts, just could be TORX head bolts.
You might think about removing the engine mount bolts
on that one side and slightly jacking up the engine, so it
will tilt just a little and give more room.
scottyboy24
Mar 6, 2016 01:00 AM
Jan 17, 2011 05:24 PM
VWspeedster
Jan 16, 2011 09:32 AM
msfreddo
Jul 27, 2009 09:06 PM
zamondo
Jan 9, 2008 03:40 PM
