VW Cabriolet '92 starting problem
Old 02-19-2008 | 08:52 PM
jashika's Avatar
Default VW Cabriolet '92 starting problem
Hi!
I have a strarting problem with my car: when the engine is at normal operating temperature sometimes if i want to start the engine the starter doesn't do anything.After 2-3 minutes the car starts perfectly.
Could it be the starter relay?The starter works perfect when cold,the battery is almost new.
Thank You
Peter
Old 03-05-2008 | 12:38 AM
volksfanatic's Avatar
Default RE: VW Cabriolet '92 starting problem
Number of things to check when car won't start:
- No fuel pressure
- no ignition spark, a bad coil
- Dirty or loose wirings and connections
- check the battery and the starter as well
Keep us posted of what other things have you noticed. By the way, have you done tune-ups lately? Better check all your auto parts to see what might be the real problem. Good luck..
Old 04-07-2008 | 11:05 PM
jashika's Avatar
Hi
I changed the ignition switch and fixed the problem.
Thank you, anyways
Peter
huyuhy
06-18-2011 12:23 AM
12-04-2010 04:41 AM
10-09-2010 09:55 AM
jashika
10-29-2007 10:13 PM
bosco
04-17-2007 08:30 AM
