VW Cabriolet '92 starting problem
Hi!
I have a strarting problem with my car: when the engine is at normal operating temperature sometimes if i want to start the engine the starter doesn't do anything.After 2-3 minutes the car starts perfectly. Could it be the starter relay?The starter works perfect when cold,the battery is almost new. Thank You Peter |
RE: VW Cabriolet '92 starting problem
Number of things to check when car won't start:
- No fuel pressure - no ignition spark, a bad coil - Dirty or loose wirings and connections - check the battery and the starter as well Keep us posted of what other things have you noticed. By the way, have you done tune-ups lately? Better check all your auto parts to see what might be the real problem. Good luck.. |
Hi
I changed the ignition switch and fixed the problem. Thank you, anyways Peter |
