Driver's door won't unlock with key
Old Dec 6, 2019 | 05:03 AM
Flyindixie's Avatar
Default Driver's door won't unlock with key
I have a 2002 Cabrio. Driver's door won't unlock with key. It will lock just fine. Windows up and down work fine with key. But for some reason it won't unlock any doors with key. Don't hear vacuum motor when trying to unlock either. So is this an issue with the lock control module in door, or the vacuum motor? And how do I test?
Old Dec 6, 2019 | 08:36 AM
I'm not sure when the vacuum central locking was finished with.
gmbwrenchn
Feb 9, 2015 09:34 PM
richmaier
Sep 17, 2013 11:10 AM
the doctor
Jan 27, 2013 03:57 PM
mohamed
Apr 16, 2012 02:05 PM
DTECK
Jun 1, 2010 02:00 PM
