Top interchange
Old Dec 14, 2018 | 10:18 PM
Russ's Avatar
Default Top interchange
Ok so I'm new to the Cabrio world so I have a question. The ole lady just got a 2002 gls. The top is separating at the seams so it needs replaced. Only thing is the top is friggin expensive. I know the difference in 2002 and the older ones is the rear glass is different,but if I'm not worried about the rear defroster will an older top mount in the same way to the 2002 frame? It is a manual top on mine. Thanks for any help.
Old Dec 15, 2018 | 07:04 AM
There are companies that make/repair cabriolet top you can Google.
Old Jul 8, 2019 | 01:11 PM
Stephane Belanger's Avatar
Default roof
did you get ananswer to roof switch as im in the same situation
Old Jul 8, 2019 | 02:05 PM
Russ's Avatar
No I have not found out yet but found a top for it with no window which for me is not an issue since top will be down when dtiven just up when parked.It was only 200 bucks.
Old Sep 23, 2019 | 11:36 AM
vailiyat's Avatar
Originally Posted by Russ
No I have not found out yet but found a top my ip birthday wishes tneb for it with no window which for me is not an issue since top will be down when dtiven just up when parked.It was only 200 bucks.
Old Dec 20, 2019 | 11:54 AM
Jack richer's Avatar
Originally Posted by vailiyat
different,but if I'm not worried about the rear defroster will an older top mount in the same way to the 2002 frame? It is a manual top on mine. Thanks for any help xender discord omegle.
donwozniak
Dec 23, 2015 07:59 AM
Dec 12, 2010 11:38 PM
Oct 9, 2010 08:56 AM
rdhoffmann
Sep 7, 2009 04:36 PM
payne782000
Dec 30, 2006 06:33 PM
