serious help please!
Old Apr 14, 2013 | 05:01 PM
vwbeattlegirl14's Avatar
Unhappy serious help please!
i have a 2004 beetle 1.8T and my current problems. P2279 , P2187 codes popped up. EPC light on. car stalled. replaced 2 vacuum check valves and brake light switch . car ran fine then all of a sudden stalled and light s came back on IE CEL ECP batterie light came on as well . please help!!!!
Old Apr 14, 2013 | 06:44 PM
VAG Error Code: 18711
EOBD II Error Code: P2279
Fault Location:
Leak in Air Intake System
Possible Cause:
Vacuum Leak.
Intake Manifold Runner Position out of Specification.
Faulty Positive Crankcase Ventilation (PCV) System or Heating Element (N79).
Possible Solutions:
Check Intake System for Leaks.
Check Intake Manifold Runner.
Check (PCV) System and / or Heating Element if applicable.
Special Notes:
When found in the NAR (North American Region) 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve.
If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
VAG Error Code: 18619
EOBD II Error Code: P2187
Fault Location:
System too Lean at Idle, Bank 1
Possible Cause:
Injectors leak/blocked.
Air Intake Leak (after MAF).
Exhaust Leak.
Possible Solutions:
Check Mass Air Flow Sensor (G70).
Check Injector(s).
Check Fuel Pump.
Check Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80).
Special Notes:
Old Apr 14, 2013 | 08:21 PM
Angry big issues
hi everyone i put up a post a few hours ago, like i said in the first one . i had two codes that where put up on a diagnostic reader . p2279 and p2187 i know what they mean . thank you to the person who responded !!! ive replaced two check valves . and replaced the brake light switch . everything was great for about 30 min then the EPC light came back on . and engine seemed like it stayed in 4th gear . then it would just shut off out of no where . battery is good. all electric stays on. today i started it drove it for 10 min went to make a turn and bam . shut off . EPC light came on again with the CEL . so im stumped any info would help thanks!
Santa Albert
Sep 9, 2013 01:24 PM
tbperry
Sep 4, 2010 09:32 AM
fyrehed358
May 30, 2009 09:42 AM
vanjoejoe00
Nov 24, 2007 04:55 PM
brzlnut
Jun 4, 2007 02:29 PM
