Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it here.
tranny problems?
Old 09-12-2009 | 10:14 PM
jonwilliams775's Avatar
Default tranny problems?
people are telling me that if i lower my 2001 golf it will give it transmission problems. is this true?
Old 09-16-2009 | 01:47 AM
lovely09's Avatar
Causes of Transmission problem
Fluid
If a transmission leaks fluid, the front pump will not be able to provide the proper amount of pressure and the transmission will not shift. Transmission fluid is a slippery, soapy type of oil that also lubricates the internal moving parts of the transmission.
Front Pump
The front pump can leak or stop working. The transmission will not work at all if the front pump is not working--it won't even go into gear.
Clutches
Both automatic and manual transmissions have clutches. Each gear has its own set of clutches. If the clutches become too thin, the transmission will go into gear, but it may not move the car.
Throwout Bearing
The throwout bearing is only used in manual transmissions. It disengages the clutch when the clutch pedal is pushed in. If the throwout bearing goes bad, it can be replaced without doing a complete rebuild.
mkedziora
12-10-2009 05:32 PM
volks23
04-20-2009 04:34 PM
northerngreaser
05-22-2008 09:01 AM
cheetah993
07-03-2007 01:52 PM
milehigh
01-05-2006 06:25 PM
Quick Reply: tranny problems?
