Temperature gauge
Old Mar 25, 2013 | 06:22 PM
Scottycv's Avatar
Exclamation Temperature gauge
Having a problem with my 04 gt tdi 2.0 golf, the temperature gauge isn't registering any temp reading. I changed sensor to standard new sensor,caused several emissions faults to happen. I then got a proper vw sensor an resolved my fault problems but temp gauge still not registering. Car blowing hot air and functioning as normal, any ideas?
Old Mar 25, 2013 | 08:10 PM
Welcome to the forum.
The first thing to check is to see if the thermostat is operating correctly. If you've never had it changed then replace it they aren't that expensive.
You could really do with having your motor scanned for any error codes logged in the ecu.
Old Apr 8, 2013 | 05:34 AM
zimrot's Avatar
Old Apr 9, 2013 | 01:19 PM
Scottycv's Avatar
Hey Keith
Thanks for response,since posting the temperature gauge has magically started working,takes a little longer than most to display temperature but now is functional to correct temp. Having problem with emissions workshop fault though,plugged in to diagnostic tool and not really giving too much away. Don't no if its related as was working fine previously before change temp sensor.
Thanks for responses
Scotty
Golf Gt tdi 2.0
oldman
Aug 27, 2011 07:40 PM
rosewater
Aug 14, 2008 09:46 PM
farmdwg
Jun 24, 2007 12:41 AM
Madness06
Oct 31, 2006 10:23 AM
Alan
Oct 17, 2006 03:18 PM
