multipul problems
Old Jul 27, 2007 | 12:18 AM
TOE243000's Avatar
Default multipul problems
ok i have i think a '80-'81 VW bug and i found the fuel pump but when i try and turn it over it doesnt even start, now i know that feul is getting to the pump it leaks alittle at the end of one of the hoses but it wont pump the feul to the engine. next there is a hose that come out next to the gas take on the right side it doesnt have anything attached to it and runs on the edge of the bottom and crosses to the left and ends at the transmittion and there is a second hose that starts at the back of the left tire and ends at the same place as the otherr hose does. (note:there is alot more problems) next how do i replace the front fender light wires and blinkers. there is more but i havnt looked at the rest yet, so there will be more post hope someone can help.
Old Jul 27, 2007 | 09:24 PM
TOE243000's Avatar
Default RE: multipul problems
opps sorry its a '76..............................................
Old Aug 1, 2007 | 10:20 PM
74superblue's Avatar
so is gas getting to the pump?? thats what you need to find out if not lines are clogged or pump isnt sucking. are you getting any fire at the spark plugs? pulla plug out o the head with the wire connected and ground it to the frame? fire? spark?
myjetta
Jul 7, 2011 10:23 AM
