Help with DTC
Old Sep 3, 2008 | 07:22 PM
MB77MONZA's Avatar
Default Help with DTC
1999 Golf mk4 manual with 147k. I just did an oil and filter change, and also replaced the valve cover gasket as it was leaking bad. Drove the car for about fifty miles and it threw a P0411 code. I must have put a small crack in the pipe from the air pump. I found the crack and repaired it with 2part epoxy putty and reset the code. about fifty miles later the code is back. As a side not I also replaced the factory radio with a new VW radio. This was a plug and play, with no change of wiring. Any ideas would be appreciated!
Old Sep 3, 2008 | 07:58 PM
Jrailer's Avatar
Default RE: Help with DTC
check the small vacume line to the deverter valve (the valve that the hose from the air pump goes to) they crack at the valve
we could use new members at the Air2 water forum have a look it wont bite
Old Sep 3, 2008 | 10:16 PM
MB77MONZA's Avatar
Jrailer,
You nailed it! The hose was broken right at the clamp and just hanging there by the thread/ cloth covering. Thanks!
Old Sep 3, 2008 | 10:44 PM
Jrailer's Avatar
no problem
Old Sep 5, 2008 | 12:21 PM
bagel's Avatar
Nice Job!!
trippme
Jul 26, 2014 10:33 AM
wrelkin123
Apr 8, 2014 08:17 PM
Nov 24, 2010 04:15 AM
kp
Jul 11, 2010 07:26 PM
Bizzle
Aug 21, 2006 10:17 PM
