Drive axle seal??
Old Sep 2, 2008 | 09:09 PM
husky100's Avatar
Default Drive axle seal??
Right side of my auto trans seems to be leaking just behind the rotating assembly at the transmission (axle assembly) Is this a common problem and is it a easy repair?? Also does the motor mounts have a black fluid in them???
Old Sep 2, 2008 | 11:55 PM
Jrailer's Avatar
Default RE: Drive axle seal??
some mounts on the early carshave a very sticky thick oil like stuff that will leak out when the rubber gets cracked dont know if its the mount braking down or old oil or if they just put it in for a little bit of a dampner
what year is your car? 90-97?
Old Sep 3, 2008 | 08:46 AM
Jrailer's Avatar
ya i think its some kind of a jelly
Old Sep 3, 2008 | 09:29 AM
husky100's Avatar
The drivers side motor mount rubber bushingis whereI thoughtthis black water type stuff poored out. Like 1/4 cup worth. There are these 2 hoses (not sure what they go to) that are connected to the bottom of the rubber bushing, and I was thinking that the fluid could also come from these.
Old Sep 3, 2008 | 08:09 PM
Jrailer's Avatar
power steering lines
they could be leeking
Old Sep 6, 2008 | 09:47 AM
husky100's Avatar
The lines seem to go under the rear of the oil pan then over to the bottom of the motor mount and then up into the driver compartment (towards that direction). It seems like a plastic cover type material over small lines. Still looking for online diagram to do a trace.
Old Sep 6, 2008 | 02:31 PM
  #7
bagel's Avatar
What year is your car? Sounds like power steering lines to me. Lines run on top of the rack??
Old Sep 6, 2008 | 07:17 PM
  #8
husky100's Avatar
2000 passat wagon. Would the lines be the size of maybe a pencil??
Old Sep 6, 2008 | 10:59 PM
  #9
Jrailer's Avatar
oh its a passat
those are trans cooler lines i think
993944S2
Nov 19, 2007 03:09 PM
dedj
Oct 25, 2007 05:00 PM
vans1170
Apr 25, 2007 12:32 AM
tdidisaster
Jan 6, 2007 12:54 PM
arejohn
Aug 1, 2006 03:45 PM
