66 era VW Engine problems starting
Old Jun 26, 2010 | 03:40 PM
wahoo54's Avatar
Default 66 era VW Engine problems starting
I've got a 66 era engine on an old dune buggy frame. I've replaced the fuel pump, added new carb kit, points, condensor. It starts and runs for a while then dies. Then if I keep cranking on it it shoots gas out the small tube on top of the carb just inside the throat. What is my problem? I've got a temp gas tank rigged up from a lawn mower and I know the fuel is OK. Help!
Old Jun 30, 2010 | 06:20 AM
mkhussey94's Avatar
Clean out the old gas and try fresh gas. Change the fuel filter now and in a few weeks also. When you add the fresh gas also run a good injector cleaner in it as well. Automotive gas is not the cleanest in the world and goes bad after about 6 months. This should solve your problem.
wahoo54
Jun 26, 2010 02:33 PM
gt_i_wish
Aug 7, 2007 04:08 PM
emceetricky
Jun 15, 2007 03:31 PM
coffeehead55
Mar 21, 2007 01:06 PM
2004Car
Sep 27, 2006 10:27 PM
