"Key in pocket" entry only works for a minute.
Old Oct 6, 2010 | 02:25 AM
piyush123's Avatar
Default "Key in pocket" entry only works for a minute.
I've had this '04 TDI for over a year and the key in pocket entry has never worked right. I get the following Permanent DTC codes:
Left Access/Start Authorization Antenna-R134 Interruption
Right Access/Start Authorization Antenna-R135 Interruption
Access/Start Authorization Antena in rear bumper R136 Interruption
Interior Access/Start Authorization Antenna 1-R138 Interruption
If I clear the codes I can get the system to work fine a few times but after I go for a ride, it quits again. Any ideas as to the cause and how get it work all the time? Could it be bad coding in the kessey? If I can get it to work, I assume the antennas are good.
onlinepersona
May 28, 2015 11:45 AM
supermarky
Oct 31, 2010 07:42 PM
ericconn
Jun 24, 2010 12:19 PM
marconious
Jul 24, 2008 08:47 AM
Anna
Sep 9, 2006 01:25 AM
