Battery Drain on Passat 110 TDI Comfortline '97
Old Apr 23, 2011 | 03:52 AM
Schoeler's Avatar
Default Battery Drain on Passat 110 TDI Comfortline '97
Hi.
I have just bought a Passat 110 Variant TDI Comfortline from '97, and the battery is drained from full charge to 6V over night.
I have bought a new battery but that doesn't help anything. I have gone through all fuses and no issues there. I have turned off every lamp in the car so no drain from those.
The car has A/C and a webasto engine heater (but I haven't used it), and a original blaupunkt radio with navigation.
Can anyone please help me, I would be most greatfull
Thanks in advance
Old May 15, 2011 | 03:14 PM
Schoeler's Avatar
Default Update
So now I have found out that the battery was faulty and couldn't hold neither it's capacity nor its voltage.
I changed the battery to a new one, and the problem seemed solve.
BUT, now the battery is yet again discharged :-( I have tested the battery and it seems fine, so my only conclusion is that something is discharging the battery.
Any ideas? I have heart that the generator could cause discharging issues, any comments?
Thank you in advance
Old May 16, 2011 | 01:49 PM
elrocco88's Avatar
It could be the alternator. Try getting it tested at one of your local auto parts store.
Old Aug 1, 2011 | 04:16 AM
Schoeler's Avatar
Hi.
It has been a while since I found out what the problem was. Firts of all I needed a new battery but even then my battery was drained occasionally. As it turned out it was a missing piece of plastic that prevent the water from running through my pollen filter and into the cabin, thus preventing every wire and electric component from being wet...
harryralston
Jan 22, 2014 04:22 AM
Aug 5, 2010 11:42 PM
medman
May 22, 2009 08:57 AM
jenviv1
Feb 14, 2006 06:53 PM
