2010 VW CC having a Problem....No good wiring diagrams
Old Feb 28, 2019 | 06:02 PM
tj2k1983's Avatar
Default 2010 VW CC having a Problem....No good wiring diagrams
Hi I have a 2010 VW CC and noticed that when I take the key out the ignition and close the doors and lock the car up, the needles for the tach and the odometer area all stay lit up. This is not the time and mileage, but the whole information system stays lit as well, and its killing my battery. Was wondering if it was a ignition switch problem or something else. VW wiring diagrams on all data are terrible, so i was wondering if someone has ran into this problem before. I just don't wanna shove parts at the car need the right diagnosis. Any help would be appreciated.
Thanks
James
Old Mar 2, 2019 | 07:28 AM
You con Google for wiring diagrams or you can find someone with ElsaWin to make them.
You can join https://erwin.volkswagen.de/erwin/showHome.do for a day and save all diagrams as a PDF file.
Old Mar 2, 2019 | 07:37 PM
tj2k1983's Avatar
Default CC
No codes in ECU
Old Mar 3, 2019 | 09:01 AM
Originally Posted by tj2k1983
No codes in ECU
With what?
Old Mar 3, 2019 | 06:36 PM
tj2k1983's Avatar
You said to have codes read. There are no codes in any of the modules. But when the car is off key out,and doors locked with fob, the needles in the cluster stay lit up. The needles for gas, temp, tach, speedometer bulb is burned out. Is that normal or is the cluster bad.
Old Mar 4, 2019 | 06:42 AM
No codes in ECU
I asked you scanned with what but you haven't said.
Old Mar 4, 2019 | 07:48 AM
  #7
tj2k1983's Avatar
Autel Maxisys 908 pro
Old Mar 5, 2019 | 08:01 AM
  #8
Old Aug 3, 2019 | 06:53 AM
  #9
paityda's Avatar
Originally Posted by Keithuk
With what?
, so i was wondering if someone has ran into this problem beforeauto clicker word unscrambler. I just don't wanna shove parts at the car need the right diagnosis. Any help would be appreciated.
Old Aug 3, 2019 | 06:54 AM
  #10
paityda's Avatar
romy.pfff
Mar 19, 2020 09:32 AM
curtis79
Jul 23, 2019 08:39 AM
Davidf
Mar 13, 2019 08:55 PM
kidd2018
Feb 18, 2018 08:41 AM
