2008 Passat oil filter housing
Old May 18, 2009 | 10:02 AM
msfreddo's Avatar
Default 2008 Passat oil filter housing
Hello,
Can someone tell me where the oil filter housing is on a 2008 Passat?
Do I need a special wrench/tools to get to it?
The paper filter through me off..What brand is recommended?
thanks,
Mike.
Old May 18, 2009 | 12:51 PM
racerx002's Avatar
I don't know where the oil filter is exactly on your car but, the filter housing itself resembles an oil filter. You just unscrew it with a normal socket wrench or regular wrench. I haven't noticed any difference in oil filters. I've used Mobil1 (about $13), and Bosch about the same price and Fram ($3.99). In my opinion I would go with the Fram.
Old May 18, 2009 | 04:07 PM
msfreddo's Avatar
thanks racerx002!
Old Jun 8, 2009 | 06:20 PM
trucky24's Avatar
I used an 1 1/2 socket to turn off the housing on my 07 passat..it worked for me..make sure u use a drain tool to drain the housing out or u will get oil on ya..did u find the housing?..mine was at the front of the motor towards the bumper. I had to take the plastic shield off under the motor to get to it.
Old Jul 27, 2009 | 09:06 PM
scot's Avatar
Default 08 Passat Wagon Oil Change
I changed my oil and filter tongiht and yes I got oil down the arm because I did not know how to drain the filter. I saw the little orange fitting in the center of the filter nut, but did not know how to go about it. Thanks.
scottyboy24
Mar 6, 2016 01:00 AM
Badtnt
Dec 9, 2012 10:46 AM
bodyglove
Feb 20, 2008 02:39 PM
CabrioComet
Feb 4, 2008 08:27 PM
zamondo
Jan 9, 2008 03:40 PM
