2000 Passat battery draining
Old Jun 27, 2009 | 12:00 PM
spiper122's Avatar
Default 2000 Passat battery draining
My 2000 VW Passat 1.8L 4 cyl. Turbo has been having a recurring problem in which the battery dies due to a fan under the passenger side head light running at all times. It is not an engine cooling fan. There appears to be a hose that runs from the fan towards the turbo charger, but without removing the engine shield i can't be sure. This fan runs as soon as I hook up batteries for a jump start, without the key even being in the ignition. Any suggestions?
Old Oct 24, 2010 | 08:17 AM
sunsquito's Avatar
Default 2000 passat battery draining
MIne just started to do the same thing. Did you ever get the problem resolved and is there any info you could pass on to me?
Old Oct 24, 2010 | 08:21 AM
sunsquito's Avatar
My car started to do this very thing last night and I was wondering if you ever got your issue resolved how you did how much it cost. Basically anything you could share would be helpful.
Old Dec 2, 2010 | 09:03 PM
yellowfish's Avatar
Same car, same issue. I just disconnected the power cable to the fan and have been driving on it since. The car has less get-up, but it's getting me where I'm going. I've read that it might be a stuck relay that needs a good whack with a mallet, but I haven't located the relay yet. If anyone has more info on this, please post. I'm going to keep looking.
Old Dec 27, 2010 | 05:35 AM
casimi's Avatar
This article is very interesting, I like it. I will always come to visit after.I will recommend your blog to my friends.
Skb Rack Cases
Old Dec 27, 2010 | 07:08 AM
casimi's Avatar
I like this info and it has given me some sort of commitment to succeed for some reason.
12v Water Pump
Vw03
Jan 30, 2014 06:11 AM
acsamples79
Aug 4, 2011 07:04 AM
c2stone
Oct 4, 2010 03:11 PM
Aberger
Sep 14, 2008 07:55 PM
aldo
Jan 6, 2008 06:00 PM
