wont start!! clutch might not be engaging
Old Apr 22, 2008 | 09:40 AM
SalvinY7's Avatar
Default wont start!! clutch might not be engaging
So my 98 jetta gt will not start. I think it has to do with the clutch not engaging or something. Nothing happens at all when I turn the key. anyone have a clue what it is? I just cant figure it out with this haynes manual that I have.
Old Apr 22, 2008 | 04:53 PM
bagel's Avatar
Default RE: wont start!! clutch might not be engaging
Either charge or replace the battery. Do you get any lights? Is there nothing no where, no accessories turn on? If that's the case, then check the starter, and then check your clutch cable.
Old Apr 22, 2008 | 10:56 PM
Jrailer's Avatar
might have a bad switch on the clutch pedal
hyd. system so you dont have a cable
if you have a test light you could check the small wire on the starter for power when you are cranking the key over
Old Apr 29, 2008 | 02:45 PM
SalvinY7's Avatar
I was told by some people here it might be that switch. I'm just not sure exactly where to find that switch. Is it under the hood or inside on the floor?
slcoc2010
May 8, 2015 11:45 AM
Gewing4
Oct 10, 2011 10:27 PM
ewin0014
May 15, 2011 02:14 PM
killer2
Jan 25, 2011 10:25 PM
cobra03terminator
Feb 5, 2008 11:22 AM
